Battery to amp fuse problem..
ascitiesburn69
Got everything wired up tonight for a local show that got cancelled.....Anyways setup is:
Audioque 2200d
Audioque SDC2.5 10"
1/0 pos and neg run from front battery to AQ 2200d with a 250amp fuse at the front battery.
4ga pos run to Cadence txa3002 and grounded in the trunk in 4ga as well.
Basically, everytime I hook the 1/0 pos and neg coming from the AQ 2200d to the front battery, either pos or neg first, it pops the fuse going to the 2200d. This is before I turn the car/ amp on just simply when I hook it to the battery.
Could it be because I have the Cadence grounded in the trunk? The cadence works fine and have never popped a fuse on that.
I'm stumped. But would hate to waste money on more fuses......
Before anyone comments..This was a temp setup just for the comp. and the amp was to be ran at 2ohms.
If I have a short somewhere then what so should I just look for a slit in the jacket in either the pos or neg run?
Local shop charging 10$ a fuse =FTL but imma go look at some less reputable shops and hopefully there cheaper.
If I have a short somewhere then what so should I just look for a slit in the jacket in either the pos or neg run? Local shop charging 10$ a fuse =FTL but imma go look at some less reputable shops and hopefully there cheaper.
Are your amp's fuses blown?
ascitiesburn69
ascitiesburn69
New Orleans, LA
ascitiesburn69
