Battery Terminals
jdc753
Truck Brigade
Does anyone know of a battery terminal that will accept at least 2 1/0 runs and possibly a single 4 or 8 gauge run? I would like to do the big 3 in my truck with all 1/0 wire and then run the audio system, however I have 2 batteries from the factory under the hood and might add a third out back if need be. I would just like to keep it clean looking and as close to factory as I can. Thanks in advance.
well that sure was fast, thanks. I always seem to forget about knu for some reason. I was thinking of using either their wire or welding wire for the big three anyways.
other then knu, the only batt term's i have seen that are comperable to knu is stinger.
I'll have to check out stingers site and see what they got but I'm sure Knu will work, I just want something straight forward and simple connection that isn't all that flashy.
I like the brass marine style terminals at AutoZone. $3.99 a pair FTW.
Did a quick hunt on their website and couldn't find anything, next time I am in there I will have to see if I can find them.
you gonna run a ground back to the front cuz of that plastic metal in that truck?
Wasn't planning on doing it for that reason, was just gonna ground to the floor of the cab, but I have been planning on running the ground back just to be safe, or I could just drop through the floor and ground straight to the frame. I ran the power along the frame so just run the ground through the hole in the floor of the cab along with the power and ground it to the frame. I have been disgustingly slow in installing stuff lol so no grounds have been made yet.
jdc753
Truck Brigade
jdc753
Mass
jdc753
