battery terminals
scrappy
I am looking at battery terminals to clean up the look of my install. I have a 4 ga and 0 ga power wire running to my amps. I am looking to do the big 3 but I want to upgrade the terminals first. Who is running aftermarket terminals? What brand are best Im leaning toward the knukonceptz ones. http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=5774765886&rd=1&sspagename=STRK%3AMEWA%3AIT&rd=1What are your guys thought? Thanks
Im running some like that that I got from PE and I LOVE them. Good terminals...the one downside is you have to be REALLY careful otherwise those **** bolts strip. The allen heads on em that is.
get this one.
From Phoenix Gold. Has one dual fusable 1/0awg and then has a 4awg and another 1/0awg that aren't fused. That thing kicks ***. I can sell it to you for $30. Its the TMC.902k
I seen the stinger ones and the kk one. Wich do you think is better and why? The pg one is that $30 for one or both because the kk one is both and the stinger is somethinh like $35 for both
Which "both" are you referring too? The positive PG terminal is $30 and the negative (which is unfused but has the same outputs) is $30 as well.
I use Stinger HPM-series terminals on both my pos and neg
There's a seller on eBay with the username bag-boy (link is for his eBay store) and he's also got an off-eBay website. Good prices, discounts shipping for multiple items, and ships lightning fast. I've bought from him more than a couple of times and was treated very, very well each time. For a matched set like pictured above you'd be looking at less than $30 including shipping for both terminals.
I am leaning towards the kk or the pg ones.The kk ones are not very expensive and the pg one is fused so I wouldnt need a fuse for the alternator run. How many feet do you think I would need of wire to do the big 3 on a durango
no more than 12 feet total between pos and neg unless you make some long runs somewhere. i would look at the factory wires and go off that. (s-10 is smaller than a durango i only used about 9 feet total)
One more question is I go with the kk ones where does the stock wire go? Does it go to the additional ring terminal? So I would have one going in on that terminal and one going out? What about the other ones is that where the stock wire goes as well?
scrappy
scrappy
nowhere
UndercoverPunk
michigan born
    May 14, 2026
michigan born
    May 14, 2026
