Battery Terminals Wiring...
94CamryBumpin
Reppin' the Gen III Camry
when using this type of battery terminal linky ...if i am connecting 2-ring terminals to the bolt do i need to seperate them with a washer or nut of some sort?or can the ring terminals be right on top of one another with the wing nut holding them down? they are gonna be 2-1/0 ga. ring terminals fyi...
If you havent already bought those terminals, look into these ones. I like them very much and they are very easy to use, and offer a lot of versatility.
Link: http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=263-677
Electrons travel through metal like water through a pipe so stacking will not affect anything.
Why do you need two 1/0g wires?, a single 1/0g should handle 200 amps of power to the trunk no problem, its doubtful your amplifiers are going to need anymore then 150 amps of continuous current and using a distro block with two 4/0g outputs will work fine as a 4/0g will handle up to 150 amps of current when kept under 4 feet in length.
Electrons travel through metal like water through a pipe so stacking will not affect anything.Why do you need two 1/0g wires?, a single 1/0g should handle 200 amps of power to the trunk no problem, its doubtful your amplifiers are going to need anymore then 150 amps of continuous current and using a distro block with two 4/0g outputs will work fine as a 4/0g will handle up to 150 amps of current when kept under 4 feet in length.
Perhaps one run of 1/0 is for his amp and the other is an upgrade for the stock wiring ...
94CamryBumpin
94CamryBumpin
Kansas
94CamryBumpin
