Neothin
1 Clean tC
Right now I have an 8 point groundwire kit running throughout the engine bay in my car. It's made out of 4 awg wire and all wires are ended with crimped ring terminals.
Herein lies my problem- The grounding kit already has 3 ring terminals on my negative post, so it's pretty much full. I want to run 1/0 awg for my big 3 but without anywhere on the battery to connect it, i think i'm in the market for a new terminal. I want to get knukonceptz wiring for my system and browsing through their site I noticed that they had terminals. The negative post terminal gives you a slot for one 4, one 1/0, and then a connector for a ring terminal. If I run the big 3 wire into the 1/0 connector, cut off the ring terminal from one of the groundwires and put it in the 4 connector, will the top ring terminal connector accept 2 rings instead of just 1?
For the positive I have a similar problem. I want to run 1/0 to the back, 1/0 for the big 3 wire, and then i have a 10 awg ring and a 16 awg ring that i have to hook on there for 2 other things i've hooked up. will the ring terminal connector accept the 1/0 for the big three and the 2 other rings that I need to hook on?
