Battery replaced but sub not hitting?
well when the battery was disconnected then the head unit loses all of its memory settings so that could be a potential issue? Idk though because the OP did say that he messed with the settings. Possibly by some accident you set the subs to hpf or something?
what up guys sorry i went out for a little. ok yes its very possible the bass was always there but the woofers covered it up. In any case the woofer doesnt hit at all and i'm not entirely sure what the deal is about the amp and how it could be turned off. but i have an aftermarket HU
do you have a fuse ...
check that then pull the truck liner and see if they hooked you power wire back up !
maybe they forgot to hook up a wire ...also where is your amp located ?
sublime1991
sublime1991
CT
sublime1991
