Battery Question?
You need to check what is the max discharge rate for hc800, if its low and you got like a ma 4000d amp, you know what happens next.
they will be fine. First of they are kinetiks so they have a relatively low ESR and the HC800 is not the only bat it will have the HC2000 with it.
Just wanting to make sure I got this right' date=' have the redtop upfront with the 800 and the 2000 in the trunk? Which battery should be closest to the amps?[/quote']
It doesn't Really Matter...If the batteries are charging then it doesn't But if your ALT isn't charging the batteries then your having problems...I would always connect the biggest one last.....Some one correct me If I am wrong
biggest one should usually be closest to the amp. And adding an HC2000 should be better than replacing the 800 with a 2400. The SPV35 is a bonus on top of that!
Im getting rid of the stinger battery and keeping the kinetik 800 and adding the 2000. So put the 2000 closest to the amps?
Crownvicon28s
God 1st
Crownvicon28s
Spartanburg, SC
chase007
