SPL Blazer
SPL Event Promoter
I seriously doubt any company is going to build an amp to handle 24 volts. The only reason someone would even run 16 volts is for serious competitions, and the limit for comps is 17 volts. 16 volts on a cars electrical system will do the same thing 24 volts will, fry your computer and everything else in the path. If your planning on a 16 volt system you better make sure your amps will handle it too, most amps can not. You can run a second alt to power a 16 volt system, but you have to make sure no part of this system is connected to the cars electrical system.
