agarabaghi
So i removed my amp and mailed it back for service.
Everything was off and all breaker (150amp for the syn6, 50amp for the sub amp) switches for the amps were turned off.
I have a dual battery setup with a Battery Doctor 100 amp Battery Isolator hooked up between the 2 batteries, also on 135amp breaker.
Hooked up the the new amp, popped back in the breakers fired up the boat, everything was running fine.
After several minutes of running the engine the battery isolator goes into:
"Charging over-current"
According to the manual, this means
"Excessive current flowing while in charging mode.
"Over current can be reset by pressing the Override/reset button or will automatically reset when the starting battery is below 12.8v indicating that the engine has stopped"
When i press the override reset the system goes back to normal for a couple seconds then back to Charging over-current mode.
What does this mean?
Link to item:
http://www.batterymart.com/p-acc-200...-isolator.html
Link to manual where you can see the specs / LED Fault lights
http://www.batterymart.com/pdfs/20090-manual.doc
Link to item:
