battery charging questions noco 7200
cocoleveo7686
MA
So i have a kinetik 2400 that rests at 12.9. I decided to buy a noco 7200 which charges it at 14.7 i believe. I think it jumps around a little to be honest. But when its done charging it stabilizes voltage to only 13.1 at most with the terminals on. There is a "power supply mode" that im not sure if its a maintenance mode but it puts out 13.6v constant.
Just trying to make sure im doing it right. Anyone have experienced aith this charger? Should i do repair (desulf mode) even tho it holds 12.9 without being charged for months and the battery is 7 months old
I just thought agms were supposed go float at 13.4-13
6
Dont wanna ruin my battery
it's probably trickle charging it, sounds right to me
doing what its supposed to. the manual should confirm this
Do u mean trickle charging it to maintain 13.0 volts? I thought the point of getting a good charger is to keep they floating at 13.6?
My kinetik has a starting voltage of 12.9 it took literally 5 minutes for the noco chargerto get to 100%. Ill leave it on there and check tomorrow but if it trickle charges at 13.0 isnt that too low?
cocoleveo7686
cocoleveo7686
MA
cocoleveo7686
