why you say that young man?Just get a battery. You're not going to pay for good caps.
/thread
You Are on top of things lately!You have two batteries under the hood which are probably 6 feet or more away from the amps.
The time it takes for the amperage to even get to the amp causes the power to lessen so you really just need another agm near the amps.
But id invest in a "real" alternator from one of the high output distributors who offer for car audio.
This advice seems to be what is happening and yes, I'd love to buy a Mechman, Singer...etc but the $140 option is what I went with. Time to order that Kinetic!You have two batteries under the hood which are probably 6 feet or more away from the amps.
Kinetic is a bit expensive for your need.This advice seems to be what is happening and yes, I'd love to buy a Mechman, Singer...etc but the $140 option is what I went with. Time to order that Kinetic!
Electricity moves at virtually the speed of light.The time it takes for the amperage to even get to the amp
Good price on that size AGM.i have two of these https://www.sonicelectronix.com/item_88298_Kinetik-HC2400-BLU.html
supporting 4k and 600 watts of mids, no big 3, stock alt, and an xs group 34 up front.
idle it physically wont drop past 12.6 and @ 1700 rpm+ i see 13.3+ all at full tilt
I found a used one locally for 100 and just ended up buying a new one to match. Don't know why I don't see more people running them. They are very stout.
they are budget friendly
Yes$$$... Wouldn't I be better off with a battery in the rear for that price?
True, but distance and wire size cause voltage loss.Electricity moves at virtually the speed of light.
Yes
I think what you mean. Is discharge rate? Batteries have a much lower discharge rate and will not stabilize charging voltage..True, but distance and wire size cause voltage loss.
Batteries cant charge fast enough to keep up with current demand.
Sent from my Z981 using Tapatalk
This***get a bank of maxwell supercaps. you can get lucky and find them for under $200 with the bus bars which is a STEAL.
keep in mind caps last 100x longer than batteries and wont lose their value like a battery
5 farads wont make a difference ,i promise you that. one bank of supercaps will change your life though lol theyre awesome if used properly
