Batteries Explained
A couple of corrections:
10% isn’t a very realistic typical percentage when comparing discharge rates C/100 and C/20 or C/8. That number can vary from a small percentage to over 50%.
Peukerts formula can’t be used in that form, because it wasn’t devised to find relationships between varying discharge rates using a specific battery capacity. It’s a pretty common mistake with textbooks.
How it’s written for specific battery capacity is:
[T/(R*C)]*[i/(C/R)]^n=C
Where R equals the battery amp hour rating ( ie, 20 or 8 or etc)
Well, I had trouble learning that formula and still have trouble understanding it, it pissed me off and I kinda left it alone for a while, and yea the book has its flaws but not every textbook is perfect ya know //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Peukerts formula cant even be used as part of figuring out how long a battery will last in a system. there is NOTHING constant powerwise in a car audio system unless you plan on listening to 15 minute test tones lol
Nothing needs to be constant.. Specd capacity of a battery with a linear or non-linear discharge is a integration of an average energy vs time.
And for the record no one said the resultant is dead on the money, but by using Peukert's formula it will be within a couple %. It's the absolute best way to mathematically determine the relationships of the battery with varying discharge rates.
will be alot more than a few % off when your figuring out the rate that energy is being pulled to by music. your current will vary from 2 amps to 110 amps (between songs there will be a huge difference in power consumption with SAME volume setting). that equation is more for trolley motors and RV refrigerators
Not very good at reading what I type are you:eyebrow:
Enough said.
It is only going to be a few percentage off at most, with a decent guess at average current. If someone really is clueless they can take a wild guess and bump load up 50% and they'll still be much closer to capacity than the spec'd AH rating.
The AH rating would be used for something like refrigerators in a RV. You're definitely a confused individual.
Enough said.
//content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif :laugh: //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif :laugh: //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif :laugh: //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif :laugh: ok what is the average current of a 400 watt amp playing full range to the Ghostbusters soundtrack at 69.2% full volume...........
voltage isnt deadly? to an amp?
The part about the higher the voltage the more dangerous to your heath is a massive ****ing lie. Static electricity builds to thousands of volts but cant carry enough current to do more than give a little pop. On the other hand, people have defribulated people's hearts using 2-3 car batteries in series.
Current is deadly, not voltage.
SyKo13
Bewb Saving Lawn Tech
SyKo13
Coachella, Ca
Thnking
