Bandpass VS Ported Boxes
  • 4
Ported. Whats the recommended size for a ported box on your spec sheet? Probably something around 1.25-1.75 cu.ft / sub. Try to stay away from bandpass, as the boxes have to be built specifically to the subs specs and they arent forgiving if you are just a small amount off with your measurements.
- Steve
as my understanding went, a bandpass will hit slightly harder than a ported(if made correctly) but will sound like a one note system. am i wrong?
Originally posted by Moocow16 as my understanding went, a bandpass will hit slightly harder than a ported(if made correctly) but will sound like a one note system. am i wrong?
Your right....the bandpass box will hit and sound like one frequency continously - unless of course the box is made absolutley perfect. I have seen many bandpass boxes struggle at certain frequencies - sounds like crap, almost like the woofers are seized.
- Steve
If you're serious about an 18 in the trunk front firing/trunkwalled go ahead. At least you got electrical covered /w/ a 600rms sub I'd wager. If...
16
is this a ported enclosure or a 4th order? If 4th and tuned to 33hz, unless specifically designed to do that, it wont have any bandwidth. It might...
I’m going to stick with the 4th order bandpass for now and see if it can improve it. The bandpass actually plays 100 rebased songs good.
Miller
Miller
Chicago,IL
nick3470
    May 12, 2024
Brendon Jenness
    May 11, 2024
