bandpass through rear deck
  • 2
k_schutte
I am going to be redoing my box here before too long and thought about going with a bandpass ported through the rear deck. I had a factory 10" in the rear deck so there is a nice open space anyways. I have a pair of RE s-e-x 10"s getting about 800~ watts rms each.
I haven't seen any bandpass/trunk builds so I was wondering if anyone has experience here? I would probably end up with really close to 2:1 ported/sealed and I have a 6" aero I'd be bringing up through the rear deck.
can work nicely if you do it right good sir //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif design it properly your good to go!
edit: driver has a decent QTS value so the box shouldnt be TOOO big
specs to help you out
Electrical Q Value (Qes): 0.46
Mechanical Q Value (Qms): 4.4
Total Speaker Q Value (Qts): 0.42
Free Air Resonance (Fs): 26.6 Hz
Equivalent Compliance (Vas): 31 liters
One-Way, Linear Excursion (Xmax): 18 mm
Efficiency (SPL 1W/1m): 83.2 dB SPL
Effective Piston Area (Sd): 310 cm2
DC Resistance (Re): 2.8 ohm
Nominal Impedance (Znom): Dual 4 ohm
Thermal Power Handling (Pe): 600 W
Force Factor (Bl): 17.7
I've never designed a bandpass but my buddy has done a ton and has quite a few trophies ans titles under his belt but he always does walls and suv's. I was thinking like .6~ sealed each and like 2-2.5 ported.
is this a ported enclosure or a 4th order? If 4th and tuned to 33hz, unless specifically designed to do that, it wont have any bandwidth. It might...
I’m going to stick with the 4th order bandpass for now and see if it can improve it. The bandpass actually plays 100 rebased songs good.
I hope you didn’t misInterpret my last message.. I was excited that I actually understand what you’re talking about… Lol! I will level with you. I...
14
If you're serious about an 18 in the trunk front firing/trunkwalled go ahead. At least you got electrical covered /w/ a 600rms sub I'd wager. If...
16
k_schutte
k_schutte
cedar rapids, IA
k_schutte
