balance help
  • 2
cwl
FL
Hello,
I have a 1991 Plymouth Grand Voyageur and have a couple of audio problems.
First, I only get intermittent sound from the left front speaker. It is the
same with two separate radio units. When I put the sound on front left
there is nothing...if I turn it up loud I get some sound from the front
right.
Second, can I get replacement speakers that will fit right the current
speaker places.
Any help you can give will be appreciated.
Thank you,
Chris
you need to pull the radio out and check the wiring for resistance. Sounds like you may have a loose connection or bad speaker. Test first before replacing
I downloaded 2 db readers for my phone to see how loud I listen to my music. Sadly they both tapped out at 95db. So for a 10min drive they both...
25
Simply put its an oldschool simple way of keeping the midbass in phase with each other when they are firing at each other in the front...
768
I also just checked the voltage and the voltage on the amp in 12.85 and the rest of my stuff like my lc2i and remote out wire is 12.10. could that...
61
cwl
cwl
FL
chris229
    May 18, 2024
    May 18, 2024
