Did you take a test light and check to see if you have voltage at the socket. Then check to see If you have voltage at the socket connector. Did you do any tests?
Not the fuse. There is only one for both. Switch bulbs. Maybe ones bad. Rust in the socket? Bad connection. Why'd you replace them if they weren't broken?
