Audiocontrol EQS (gray)
  • 1
firemedic7733
Audiocontrol EQS
8/10 because unit is used. No obvious scratches, works flawlessly
The EQS is a 6-channel equalizer/line driver. There are are dedicated 7-band graphic equalizers for the front and rear outputs, and a 6-band graphic equalizer for the subwoofer output.
Dual Bandwidth Equalization: A total of 13 bands are available over two bandwidths:
Front/Rear EQ: Two 7-band equalizers feed the front and rear outputs; the center frequencies of both are 120 Hz, 160 Hz, 250 Hz, 500 Hz, 1 kHz, 2 kHz, and 10 kHz. The rotary knobs adjust the signal +/-12 dB. There's a notch at each knob's center position so it's easy to return to the flat setting.
Subwoofer EQ: A 6-band 1/3 octave equalizer feeds the subwoofer outputs; the center frequencies are 31.5 Hz, 40 Hz, 50 Hz, 63 Hz, 80 kHz, and 100 kHz. The rotary knobs adjust the signal +/-12 dB. There's a notch at each knob's center position so it's easy to return to the flat setting.
Line Driver: To achieve the best possible signal to noise ratio and dynamic range from your amplifier, the built-in line driver can increase the head unit's output voltage up to 18 dB (9.5 volts RMS/13 volts peak).
Input Gain: The input gains for the front, rear, and sub channels are set independently. The range is adjustable +/-12 dB to match the source output to the EQ input.
Output Level: The +20 dB maximum output level allows you to increase the head unit's line voltage to the top of your amp's input range; up to 9.5 volts RMS/13 volts peak.
Balanced Inputs: Using the balanced differential input circuit cancels noise picked up in the transmission line between the EQS the the source unit.
Ground Isolation: The power supply ground is switchable, in case of ground loop noise. The factory position is fully isolated (typically the best choice), but can be changed to Ground or 200Ω.
Auto Select Inputs: The EQS automatically switches the inputs to maximize the equalization controls, whether you use two, four, or six preamp inputs.
Speaker Level Inputs: The 4-channel speaker level inputs are compatible with most factory installed radios, even most Bose systems.
Terminal Blocks: The power/ground/remote terminal and the speaker level input terminals are removable; the wiring is attached to the block, then the block is plugged into the EQS. The terminal block will accommodate wire up to 12 gauge.
Subsonic Filter: The subsonic filter crossover point is 33 Hz. The crossover point is governed by a replaceable chip, so it can be modified.
Specifications:
Maximum Line Input: 15 volts RMS
Maximum Speaker Level Input: 100 watts/channel
Maximum Output: 9.5 volts RMS/13 volts peak
Frequency response: 10 Hz-100 kHz; ±1 dB
THD: 0.003%
S/N Ratio: 110dB
Balanced Input Noise Rejection: 60 dB
Input Impedance: 20 kΩ
Output Impedance: 150 ohms
$200 PayPal shipped to lower 48
Open to trades, especially a decent set of subs
Shipping to lower 48 included
Fully test it without the ACR-1. TBH it sounds like an amplifier issue. Try connecting your phone direct to the amp via a 3.5mm to RCA cable. If...
755
Good thing its under warranty and that you have contacted A.Control about the issue so it has been documented. It will help speed up the return...
Looks like half a dozen other makes/models on the market, rebranded . The shallow mounts look like they’re made by Pioneer but what the hay, one...
Go to DIYMA some people there are willing to remote tune it for you for a small fee. Usually around 30-50 dollars.
firemedic7733
firemedic7733
firemedic7733
Decebal
    Jun 10, 2024
