MMC Racing
The factory Bose system is just terrible. I plan to keep the source unit since everything is so integrated, but add the following:
1 JL Audio 10w7 sub side mounted in trunk in fiberglass/MDF enclosure
1 JL Audio HD750/1 amplifier to run the sub
1 JL Audio HD600/4 amplifier to run the component set(s)
Boston Acoustics Pro60SE component set (dumping the current 3-way config)
Boston Acoustics Neo Type-M Imaging System
A line driver from AudioControl - probably a LC8
Dynamat as needed
I will probably dump the center channel speaker all together and only add back rear speakers if needed.
I'm interested in hearing feedback from G35/G37 owners or owners of similar sized coupe vehicles. My main music tastes are hard rock, metal, and a little hip hop. Thanks.
-Mark
Dynamat as needed
-Mark
