Constant 12V+ White Ignition Switch Harness Starter Black/White Ignition Switch Harness
Ignition Black/Yellow Ignition Switch Harness
Ignition 2 White/Black Ignition Switch Harness
Accessory Yellow Ignition Switch Harness (Heat/AC)
Tach Blue 24 Pin Connector above Fuse panel
Neutral Safety Wire Gray (-) Gear Position Switch
Brake Switch Green/White Brake Switch
Trunk Release Yellow/White (+) Switch
Trunk Pin Blue/Black (-) 22 Pin Factory Alarm Connector behind Driver's Kick
Parking Lights Red/Black (+) Green Connector above Fuse Panel
Head Lamp Red/White (+) Fuse Panel Red/Blue High Beam
Factory Disarm Yellow Driver's Kick Panel this is Ignition. for Alarm use Relay
Door Trigger Light Green/Red (-) Gray Molex Driver's Kick or Alarm Connector
Door Lock Green/White (-) 22 Pin Factory Alarm Connector Driver's Kick
Door Unlock Green/Orange (-) Must use Relays
Driver's Lock Blue Left Kick Panel
Driver's Unlock White/Red Left Kick Panel
Passenger Unlock Yellow/Red Left Kick Panel
Horn Wire Gray/Silver (-) 22 Pin Factory Alarm Connector Driver's Kick
Windows Up LF=Red/Blue, RF=Blue/Yellow, LR=Green/Yellow, RR=Yellow
Windows Down LF=Red/Yellow, RF=Blue/Orange, LR=Green, RR=Yellow/Green
