Can anyone find me a wiring diagram?
2008 Dodge Challenger DirectWire 2.0 Vehicle Information
All Products
Item Wire Color Polarity Wire Location
12 Volts red + battery or TIPM
The TIPM (Totally Integrated Power Module) is in the engine compartment, on the passenger side fender. The battery is in the trunk.
Second 12 Volts N/A
Starter lt. green or yellow/gray (not for remote start) + starter or TIPM, green 26 pin plug, pin 23
Second Starter N/A
Ignition pink/white (not for remote start) + Wireless Ignition Node, 12 pin plug, pin 3
The Wireless Ignition Node is part of the ignition switch.
Second Ignition N/A
Third Ignition N/A
Accessory red/orange (not for remote start) + cigar lighter
Second Accessory N/A
Third Accessory N/A
Keysense N/A
Data Bus N/A
Can Bus High white/black data Wireless Ignition Node, 12 pin plug, pin 5
Can Bus Low white/lt. blue data Wireless Ignition Node, 12 pin plug, pin 6
Can Bus Sw N/A
Power Lock purple/dk. green - 330 ohms driver kick or instrument cluster, gray 26 pin plug, pin 5
Power Unlock same as power lock - 100 ohms
Lock Motor lt. green 5 wire driver kick or instrument cluster, gray 26 pin plug, pin 12
Driver Unlock Motor tan/lt. green 5 wire driver kick or instrument cluster, gray 26 pin plug, pin 11
Passenger Unlock Motor tan 5 wire passenger kick or instrument cluster, gray 26 pin plug, pin 26
Parking Lights (-) white/brown -1.67Kohms headlight switch or instrument cluster, gray 26 pin plug, pin 3
Parking Lights (+) white/purple + passenger kick, harness to rear
Hazards white/dk. blue - hazard switch
Turn Signal (Left) white/lt. green (F), white/dk. green ® + TIPM, green 16 pin plug, pin 10; green 26 pin plug, pin 10
Turn Signal (Right) white/tan (F), white/yellow ® + TIPM, green 16 pin plug, pin 3; green 26 pin plug, pin 4
Headlight white/brown -1.2K ohms headlight switch or instrument cluster, gray 26 pin plug, pin 3
AutoLights same as headlight
Reverse Light white/lt. green + passenger kick, harness to rear
Left Front Door Trigger purple - driver kick or instrument cluster, white plug, pin 3
Right Front Door Trigger purple/white - pass kick or instrument cluster, white plg, pin 16
Left Rear Door Trigger N/A
Right Rear Door Trigger N/A
Dome Supervision yellow/white + passenger A pillar or instrument cluster, white plug, pin 12
Trunk/Hatch Pin purple/orange - passenger kick or instrument cluster, gray 26 pin plug, pin 23
Rear Glass Pin N/A
Hood Pin purple/lt. blue - hood switch or TIPM, blue plug, pin 10
Trunk/Hatch Release purple/tan - release switch or instrument cluster, gray 26 pin plug, pin 22
Trunk Release Motor black to tan/yellow 5 wire passenger kick or instrument cluster, white plug, pin 24
Fuel Door Release N/A
Power Sliding Door (Left) N/A
Power Sliding Door (Right) N/A
Factory Alarm Arm factory remote only
Factory Alarm Disarm factory remote only
Disarm No Unlock Sentry Key and ignition
Trunk Alarm Shunt N/A
Tachometer NOT brown/yellow ac any fuel injector
Wait to Start N/A
Neutral Safety N/A
Clutch Pedal
Fuel Pump dk. blue/orange + Power Distribution Center or fuel pump
The Power Distribution Center is in the trunk. The fuel pump is under the rear seat.
Rear Defroster dk. blue - latched HVAC control module, lt. gray plug, pin 5 or 6
Mirror Defroster same as rear defroster
Left Front Heated Seat lt. green/gray - heated seat switch or instrument cluster, white plug, pin 18
Right Front Heated Seat lt. green/lt. blue - heated seat switch or instrument cluster, white plug, pin 19
Speed Sense dk. green/brown ac PCM, plug (C4), pin 32
The PCM (Powertrain Control Module) is in the passenger side rear corner of the engine compartment.
Brake Wire dk. green/white + brake pedal switch or passenger kick, harness to rear
Parking Brake gray/black - parking brake switch or instrument cluster, gray 26 pin plug, pin 18
Horn Trigger dk. green/orange + horns or TIPM, black plug, pin 3
Wipers brown/white (L), brown/orange (H) + wiper motor or TIPM, black plug, pins 13 and 12
Left Front Window (Up/Down) motor part of module
Right Front Window (Up/Down) motor part of module
Left Rear Window (Up/Down) N/A
Right Rear Window (Up/Down) N/A
Sun Roof (Open/Close) motor part of module
Sun Roof (Limit/Close) N/A
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Radio 12V red/orange + radio, gray 22 pin plug, pin 1
Radio Ground black/lt. green - radio, gray 22 pin plug, pin 12
Radio Ignition (CAN BUS)
Radio Illumination (CAN BUS)
Factory Amp Turn-on (CAN BUS)
Power Antenna gray/orange + radio, gray 22 pin plug, pin 7
Left Front Speaker (+/-) gray/purple - gray/yellow +,- amplifier, 14 pin plug, pins 1 and 7
The amplifier is above the driver kick. The dash speaker wires are gray/orange - gray/yellow at the amplifier, 20 pin plug, pins 1 and 10.
Right Front Speaker (+/-) dk. green/purple - dk. green/yellow +,- amplifier, 14 pin plug, pins 2 and 8
The amplifier is above the driver kick. The dash speaker wires are gray/dk. green - gray/lt. green at the amplifier, 20 pin plug, pins 2 and 11.
Left Rear Speaker (+/-) dk. green/tan - dk. green/gray +,- amplifier, 14 pin plug, pins 3 and 9
Right Rear Speaker (+/-) dk. green/brown - yellow/gray +,- amplifier, 14 pin plug, pins 4 and 12
Center Channel (+/-) gray/brown - gray/orange +,- amplifier, 20 pin plug, pins 3 and 12
Subwoofer (+/-) gray/brown - dk. green/brown +,- amplifier, 14 pin plug, pins 5 and 13
the727kid
the727kid
St. Pete, FL
the727kid
