Att: box desgners
I don't know what those subs are (judging by the name, I'll assume DD?), but using 10" as a depth, you only have 4.5 cubes gross. It'll be more like high 3s if you max out the enclosure. 6 8s is a lot of speakers for only having limited area.
With those dimensions I only got 2.55 cubic feet NET.....
If you could bump your height up to about 20" then you would have 3.78 cubic feet NET which would give you alot more room to work with.......
I would prolly only do 2 good 10's with alot of wattage //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Using the 10" of depth is assuming his 6" top depth is 10"........His depth is only 8".....10" bottom depth+6" top depth=16"/2"=8"
With those dimensions I only got 2.55 cubic feet.....
Total space equals:
55.75 x 10 x 14 = 7805/1728 = 4.52 cubes gross
If you account for wood:
54.25 x 8.5 x 12.5 = 3.33 cubes before port and woofer.
When you factor in the slant, you have 2.5 cubes. Regardless, it's too small. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
ok, what would you suggest for a loud daily? I dont want to loose any seat room though, being that Im kinda tall, and its a reg cab. maybe 1 12 ported on a 2500d or something, just want it loud.
FLOSSINON24S
FLOSSINON24S
GREENBRIER, TN
FLOSSINON24S
