ascendantaudio - Poly 6.5 mid
ngallucci
What do you think of this mid-bass? I want to add more midbass to my front stage - thinking about getting 2 for each door
I have focal utopia component 6.5' 2 way currently
"Poly 6.5 mid
High excursion combined with high performance make this midwoofer perform second to none.
The $35 price is still being offered for this magnificent midwoofer. It works equally well in home and car audio setups. It is finding its way into many a home theater with amazing results. " (http://www.ascendantaudio.com/)
- Driver Features -
- Solid Copper shorting sleeve
- Solid Aluminum phase plug
- Split coil design flat-BL design
- Ultra low distortion
- Extreme excursion - 11.5 mm one-way
- Opposed tinsel leads for linear performance at higher excursions
- High quality spider
- Rubber surround
- Open frame cooling vents for voice coil
- Curvilinear cone profile
- Ultra low inductance
- Flat and extended frequency response
- Incredible bass output in sealed or ported designs
- Infinite/open baffle compatibility
- Neodymium motor structure
- Detailed sound
- High output capability
- Cast metal frame
- Fully sheilded design
- Light weight and easy to mount
- Reflection free compact motor structure
Poly 6.5 Specs Top of Page
T/S Specs Driver Specs
Znom 4 ohms BL 5.43 n/a Cutout diam. 5 13/16
Re 3.2 ohms Sd 140 cm2 Outer diam. 7.00
Fs 46 Hz Mms 16 g Mounting depth 3 3/16
Vas 20.8 L Xmax 11.5 mm Weight 2.6 pounds
Qms 2.714 Spl 88 dB 1W/1M Voice Coil diam. 1 1/4 inch
Qes .501 Rec. Power 25-100 W Voice coil 4 ohm
Qts .423 Rms 100W Cone Curvilinear Poly
Le .05 mH Price $35.00 Warrranty 3 years
well i have a pair but i cant really comment on their mid-bass performance because i have them installed in some kick panels i made that arent sealed so for me the mid-bass is practically nonexistant.
that is why i am going to throw a pair of kicker 8" mid-bass drivers in the doors (SSMB8)
i did have some problems with tensil slap but i fixed that pretty easily.
so they are very good drivers for the money but i am not sure of their low end performance.
~Magick_Man~
ngallucci
ngallucci
San Jose
helotaxi
Mike Mccabe
