RangerDangerV2
Just custom ordered an apxx 18" with 856 motor (4 inch 8 layer vc) and upgraded suspension with quad tensil leads.... can she take 5k daily???
I thought you ordered it last week?Just custom ordered an apxx 18" with 856 motor (4 inch 8 layer vc) and upgraded suspension with quad tensil leads.... can she take 5k daily???
there are plenty that will take a 5k watt amplifier just depends on other factors bringing the power down. I ran a z1 at .37 to a shocker sig for months no problem.You'll blow it up fast if you're not very careful. There isn't a conventional woofer on the planet that can handle 5000W of heat for more than a couple minutes. I suspect if you don't play below tuning mechanically it should hold up fine.
I know a guy that runs single subs off his 5K and he has blown everything we have put on it.
.5 ohmswhat impedance wull you be running it at?
what kind of electrical to back it up?
what's your enclosure volume after displacements?
There is a difference between hooking a 5kw amp to a speaker, and actually running 5kw through said speaker for a prolonged period of time. If you want to say your speaker is handling your 5kw amp, but then discuss things like impedance variations (rise) or charging systems that limit the amplifier output, you cannot say your sub is actually handling 5kw.there are plenty that will take a 5k watt amplifier just depends on other factors bringing the power down.
You need to research the people whom are talking to you //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gifwhat did you think of them and what was your setup?
