Apsm 1500
will do rated and is an awesome amp. @cat man knows about them pretty well. i ran an apsm1300 and it sounded better than my hifonics 2kd
yeah on a power bd 500 yeah a bit ghetto but works out fine in a 3 chamber enclosure even each has thier own 4in aeroport and 2.45cu ft
but just got a pair of hx2 power series 12's I am going to run on the apsm in my 84 olds
ya just run the 2 12s lol
Ok I just picked up a Audiopipe APSM 1500 bnib off craigslist for 50 bucks. What can expect from it? will it do rated and is it dependable/sturdy for daily will be running 2 RF hx2 power series 12's on it.
I doubt you can expect "clean" power, but if your goal is to satisfy a spl meter, they will work. A S/N ratio of 70db is about 10db lower than I will buy in any amplifier, personally. You seem to have the electrical to support it, which is where I suspect most people who have mechanical troubles with them fail. For $50, it is a ok deal...they are only about $120 new online. No where near the quality of the Amp you have now, but with your choice of equipment, I doubt you will be able to distinguish the sonic differences anyway.
Anyone use 1 of these?
Yes. And you got a GREAT deal. Just set it with a dmm to 1200-1300 watts, since your electrical will not stay at the 14 volts it requires to make rated.
Will do 1500 cleanly.
Not below 14 volts.
Really? My maxxsonics 2k sounds worlds better than my old apsm1500.... and it doesnt make my coils stink when the voltage drops even just a lil bit... and its louder.
audiopoop is just rebadged sundown. //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
how dare you compare AP to that crap offbrand....
I use Waze on my 1500 NEX. The one time I did have issues I had to delete weblink and redownload it. I have location to "while using" on weblink app.
340
This would go a long way to alleviating the dimming issue, up to around 4000 watts. It can handle 100A continuous and up to 285A 7 second burst...
573
Well, there is always a bypass that can be McGuyvered. So next time you want to tackle that task, post it. We can help.
928
All you need. I've been running these for years in 3 different vehicles. https://www.amazon.com/dp/B01BL57JO2/?tag=caraudiocom-20
834
I had two Skar amps (4ch & a monoblock) go bad within a year. Post #2 is an excellent recommendation.
gumby688
gumby688
Fryeburg,ME
naughtyca
    May 16, 2024
    May 16, 2024
