Nope, I wasn't paying $900 for this amp. This amp cost me somewhere around ~$370 (if I recall correctly).
Not wanting to start debate, but the little brother of this amp (spec: Model : LM Audio - LM 2200.1D (Class D) ▪ 1 Channel Class D POwer Amplifier ▪ 1 x 2000 Watt (1 Ohm) ▪ 1 x 500 Watt RMS (4 ohm) ▪ 1 x 1000 Watt RMS (2 ohm) ▪ 0.30% THD at 1 Watt, 4 Ohm ▪ 20Hz - 250Hz Frequency Response ▪ 0 + 18dB Bass Boost ▪ Power Output in 4 Ohm : 1 x 400W ▪ Power OUtput in 2 Ohm : 1 x 800W ▪ Low Pass Filter : 50 - 150Hz ▪ Sub Sonic Filter : 15Hz - 40Hz ▪ Phase Shelf Control Continous : 0 - 180 ▪ Remote Sub Control : Yes ▪ S/N Ratio : >100dB ▪ THD :
I know MMATS 1400.1 put out more than 1400 Watts RMS @ 1 ohm, then if the 2200.1 beat MMATS 1400.1, then this 3200.1 must have more power. FYI, the 2200.1 use 30A x 4 fuse.
