Approx RMS
wilson_gau
My amp (guts) look like this. What do you think the approx RMS (at given OHM: 8, 4, 2, and 1 ohm - since this is NOT 0.5 ohm stable)?
The spec is:
Model : LM Audio - LM 3200.1D (Class D) ▪ 1 Channel Class D Power Amplifier ▪ 1 x 3000 Watt (1 Ohm) ▪ 1 x 700 Watt RMS (4 ohm) ▪ 1 x 1300 Watt RMS (2 ohm) ▪ THD at 1 Watt, 4 Ohms : 0.30% ▪ THD at 1 Watt, 4 Ohms : 0.50% ▪ Signal - to - Noise ratio : 100dB ▪ Frequency Response, at 1 Watt, 4 Ohm : 15Hz to 150Hz (+/- 3dB) ▪ Frequency Response, at rate power, 4 Ohms : 20Hz to 250Hz (+/- 3dB) ▪ Damping factor at 20Hz, 4 Ohm : 400 ▪ Crossover Low Pass : 50Hz - 150Hz 24dB/Octave ▪ Crossover Subsonic (High Pass) : 15Hz - 40Hz, 24dB/Octave ▪ Bass Boost : 0 + 18dB ▪ Phase Control : 0 to 180 Degree ▪ Input Sensitivity : 100mV to 2V ▪ Input Impedance : 10K Ohm ▪ Line Output Impedance : 100 Ohm ▪ Peak Current Consumption, at rated power into 1 Ohm : 160 Amperes ▪ Dimensions : 20'L x 7'W x 2,36'H ▪ Fuse Rating : MFU 80A x 2
On the other end, could you explain if calculating the RMS for blade fuse (which is most common in amp) with this kind of fuse (tube fuse)? - ie. given the same efficiency for both amps, will an amp with 60A x 2 tube fuse has the same output with another amp with 30A x 3 blade type fuse?
Thanks for any input!
Sorry, not familiar with the clamp (or those testing method). I just need a ballpark of what the RMS you think based on the guts. I know the fuse is 80Ax2, but unsure if a tube fuse has the same rating as blade fuse..
I am not up to date with tube amps so I cant help with that. But clamping is a method to see what power you are actually getting from a certain amp. Internals look nice though so I would expect some good power from it but how much IDK.. I would say any easy 2k@ 1ohm maybe alot more.
I do believe tube fuse amperage is equal to blade fuse... They are just different types of fuses... But regardless, no one can just guess the RMS of the amp :/
a ballpark est is an amps max RMS at its lowest stable ohms will be around 80% of its fusing.
This is just a rule of thumb
so on your amp if it is 1 ohm stable then at 1 ohm you should be around 1,600 watts max RMS
I got that by 13 (volts) x 160 (amps) x .8 (80% efficient) = 1,664
So I would say its rating of 1,300 watts @ 1 ohm is likely
Each doubling of OHMS drops RMS by half so...
1,300 watts @ 1 ohm
650 watts @ 2 ohm
325 watts @ 4 ohm
He did not say he had a tube amp, he has the glass tube style fuses.
Also how would an amp with 160 amps of fusing do an easy 2,000 watts?
It would have to be over 100% efficient, the only amps I know of like that are the BOSS amps (joking)
Just cause an amp is fused for 160amps does not mean it can not pull more then 160amps without blowing the fuse..
it all depends on how you want to measure things.
You are right, an amp CAN pull more amps than its fusing -- but only for very short bursts
I like to use how much power an amp can continually produce - like on a 50 hz test tone
So we are both right - it is possible that the amp the OP has can hit 2,000 watts
and I think it is also very likely that the OP's amp can continuously produce around 1,300 - 1,600 watts
Either way it is a beast of an amp and puts my little Audiopipe to shame.
it all depends on how you want to measure things.You are right, an amp CAN pull more amps than its fusing -- but only for very short bursts
Good deal we were both on the same rd just looking at it different. Yea but ur AP was cheap for all we know the OP payed $900 for this amp so he might have got the rip hammer brought down on him.
He asked for the RMS output of the amp, what you're referring to is just peak draw and has no bearing on the situation whatsoever //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
The company 'calls' the amp a 3200.1, this is likely peak power. Many companies that list 'peak' power usually translate into ~1/2 that RMS. Also, its fused at 160A w/ AGU fuses.
I would say ~1600wrms @ 1ohm is reasonable for this amp. Maybe slightly more.
I beg to differ the draw of an amp does apply to what kinda power you will see from an amp.... So since u seem to be intune with the whole audio world what is the true rms of this amp?? Thats right u dnt know just like no one else does.
wilson_gau
wilson_gau
Seattle, WA
DaveVT
