Any problem bridging an amp into 8 ohms?
My point is: you shouldn't be OK with the 1 extra watt... you should call and complain to the company, write your congressman or something.
With gas prices threw the roof, the economy in the toilet, and the cost of living getting higher, the LEAST they could do is give you alittle more than 1 extra watt in your car amplifier.. If they wont, they could atleast not give you a certificate stating the fact that your amplifier, if personified, would ride the short bus to school everyday, "Barely making the minimum"
That sheet of paper is alittle like jerking off without the big finish.... I say destroy it. Youll be better off in the long run.
you find me another good quality amp that is 12 cents per watt
talkin about tiny lol:D
ok...let me make my picture smaller:p:
you should be so proud of your little guy.. 1 extra watt.. thats all he can do for you... 1 over the ****ing minimum... ID BE FURIOUS AT IT.
Do you understand how insignificant even 250 watts is at that point? If the amp even put out 1500w its only 20% more than rated, which wouldnt even yield a 1 dB difference..
Most home theater amplifiers are significantly overrated and nobody cares because the only way your amp will ever put out full output is on a) burps or b) since wave and if you listen to music your amp rarely goes over 50% output even at high listening levels.
I seriously hope you are joking with this whole "everything needs to be underrated" thing..
Auto: 96 honda passport 3.2L v6 4X4 5sp
Big 3 with solid copper 2awg
Hu: DEH-P7500MP
Front: Hart HT400II
Arc audio 4025 set
Rear: Stockers(4x6)Roofboxes
Woofers: PG RSD10d x2
Sub Amp: PA BB1250.1D (37vac @1ohm)
Enclosure: custom 2cu.ft. per woofer @ 24hz.
Power: Knu KLM 1/0->distro->2 eNetic silver 4awg
Ground: 2 eNetic silver 4awg->distro->Knu KLM 1/0
Auto: 96 honda passport 3.2L v6 4X4 5spBig 3 with solid copper 2awg
Hu: DEH-P7500MP
Front: Hart HT400II
Arc audio 4025 set
^^^^^what he said....Big Bang series by planet audio
TylerDurden08
TylerDurden08
Southeast
TylerDurden08
