Another set of 6.5 component fast opinions needed for overall comparisons
Hell, a PPI p600.2 would power those just fine ..... Or a p900.4 bridged would give TONS of headroom. And both are under $200 ....
Soundstream tn 900.4 I got one for my buddy, exactly the same performance as my ppi 900.4 with much better positioned speaker and power/ground terminals with nothing blocking a direct screwdriver path and it has better screws that are less prone to stripping. Not to mention they included 0 guage amp inputs. All for 125 dollars shipped. I dont think i'll ever recommend the ppi 900.4 again when the soundstream's casing is significantly better to work with and the performance is identical and is 55 dollars cheaper. Wired the soundstream down to 2.66 ohms bridged as well keeps cool with zero issues.
other amps outperform that by far sadly. Its nice but if listening to loud music, the amp taps out real quick compared to A LOT of other choices out there.
Buddy swapped his jl slash 300.4 with the soundstream 900.4 and had significant gains which he was seriously doubting because it wasn't a good brand name, however those amps are direct hertz hcp4d clones and do rated power on the dyno. The soundstream was supposed to be for his girlfriend's car but i convinced him to try it out after testing it in my ride and now his girlfriend gets the JL and he's keeping the SS.
I was actually hoping you would chime in and tell him about the SS amps. I was in a hurry. I'm actually considering swapping all my p600.2's for the TN900.4's bridged when i rebuild my front stage next month.I'll have 7 of them on my front stage then.
Well the best friend of my aunt's cousin does not agree. He said there is a lot of crappier amps you can buy for that price.
I do not see a problem with an addition of up to a 600 RMS Class D mono amplifier with 4 ga OFC wiring supply kit and be fine. It would be...
10
477
They managed to turn Covid into a wedge issue.
Pioneer lists the wattage different than sonic. Pioneer says That amp listed will do great with these speakers. You can play em at 125w no...
I think you will be just fine to be honest. Id run it and check it after hammering on it quite a bit and check the temp on the wire by hand to see...
Androidaaron36
Belleville mi
marc2112
    May 12, 2024
Brendon Jenness
    May 11, 2024
