another blow through box help
Bggd_GMC
Low & Loud
I'm getting 2 zv4 15s and I want to start working on my box but have nothing to go off of does anyone know how many cubes I should go with? There going to be in a single chamber box port in the middle tuned to 30hz... any idea 4 6 8 cubes?
A 15x16x30 box with double 1.5" wood all around and a port 13x6 with a length of around 18" gives you right around 8.5net tuned to 30 with 136sq in of port.
I was messing with a box calculator and got 124sq in of port 8" wide port 35" long box is 7.66 net 30hz
That sound like a good box? Those are with my max measurements... wish I could post pictures of how it says on the calculator
I do not see a problem with an addition of up to a 600 RMS Class D mono amplifier with 4 ga OFC wiring supply kit and be fine. It would be...
10
648
They managed to turn Covid into a wedge issue.
Pioneer lists the wattage different than sonic. Pioneer says That amp listed will do great with these speakers. You can play em at 125w no...
I think you will be just fine to be honest. Id run it and check it after hammering on it quite a bit and check the temp on the wire by hand to see...
Bggd_GMC
Low & Loud
Bggd_GMC
Fresno, CA
Bggd_GMC
    May 22, 2024
    May 22, 2024
