annoying problem
try switching the stereo ground to bare metal and not no cheap sheet metal or if u want to for sure test the ground take a piece of wire and run a ground from the stereo straight to the battery see if that fixes it then u know its a bad ground
Well then the HU ground could be bad then because if your getting the same problem with the woofer amp off it shouldnt be your woofer amp ground.
Could have 2 wires behind the HU touching or moisture somewhere also?
thats true do u have any wires back there not hooked up like cell mute, pwr antenna, illumination make sure the ends and not slightly exposed but most likely a bad ground if this is ur second radio
GOTTER-DONE fellas!!! well, turns out, buddys of mine thought it would be cute to pull on my wires to my amp.. well, the crossover and amp ground were lose, causing a bad ground connection. Got it all done!!! thanx for all the help guys!!!
well when you said you re did all your wires thought you woulda caught that //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
glad you got it fixed man //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
aj200415
aj200415
wavetown,ohio
aj200415
