Annihilator audio King Kong torture testing
AnnihilatorAudio
CarAudio.com Recruit
Quick freeair video.
Note this was Two ohm nominal not one ohm. Set the clip limiter and cranked it.
Sub survived but it pushed the suspension and moving parts beyond what I'd recommend. This was done to find out if the build techniques where adequate. Needless to say I'm going to compete with this same woofer on the 5th.
20897
20898
20899
20900
20901
Still have to do the false floor on the amp rack. Everything is isolated and will be sealed up around the rack with a push pull fan configuration.
To busy building woofers to mess with it right now. But Sunday it should be done.
154 on two 7500s? God I would hope so.
Did a build in a crew cab Silverado with two HDC3 18s on two 2200s that did a 153.8 ported leaving the 40 split of the rear seat in.
The siq amps are Sq beast as well. And much cheaper. Made by s&I in Korea iirc
122
Ill check it out. I was actually on the site last week. Thanks!
277
if you can read a simplistic book you can follow the directions to put together just fine. Its not rocket science. If you have questions about the...
294
AnnihilatorAudio
AnnihilatorAudio
Louisiana
AnnihilatorAudio
slater
    May 2, 2024
slater
    May 2, 2024
