Annihilator audio King Kong torture testing
AnnihilatorAudio
Quick freeair video.
Note this was Two ohm nominal not one ohm. Set the clip limiter and cranked it.
Sub survived but it pushed the suspension and moving parts beyond what I'd recommend. This was done to find out if the build techniques where adequate. Needless to say I'm going to compete with this same woofer on the 5th.
20897
20898
20899
20900
20901
Still have to do the false floor on the amp rack. Everything is isolated and will be sealed up around the rack with a push pull fan configuration.
To busy building woofers to mess with it right now. But Sunday it should be done.
154 on two 7500s? God I would hope so.
Did a build in a crew cab Silverado with two HDC3 18s on two 2200s that did a 153.8 ported leaving the 40 split of the rear seat in.
80a Alt. is your problem....i have a 2017 spark, no way i would go over 1000rms on stock electrical in that thing....and your cap aint doin...
87
204
if you can read a simplistic book you can follow the directions to put together just fine. Its not rocket science. If you have questions about the...
246
660
AnnihilatorAudio
AnnihilatorAudio
Louisiana
AnnihilatorAudio
GoldCountryCA
    Apr 26, 2024
GoldCountryCA
    Apr 26, 2024
