tcguy85
- Thread Starter
- #46
first of all thanks for the kind words. i appreciate it. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gifmost certainly looks better than it did before, and best of all your happy with the sound of it, the cosmetics can always be worked on.
I have been working a lot lately on tweeter placement in my truck so I will probably take some cues from your install here. Gonna have to raise them up to ear level to help out. I have heard they are better on axis and it seems to be the case but my ear still needs training. If I am not mistaken they are Vifa XT-25 or similar tweeters, the ones in the Polk SR6500 component set.
Did you ever have them installed in the pillars firing directly at each other? I know you had them in the kicks but not sure if you experimented with them up in the pillars in this configuration.
Also curious if you had ever tried them firing on axis at the opposing seat? I know this wouldn't work for a 2 seat car but thinking it might be a bit more cosmetically pleasing and may achieve a good 2 seat car.
Either way your progress looks good, the pillars certainly look nice with the suede on them, some fiberglass and smoothing out the shape and you would most likely be golden.
i tried them in the kicks on-axis and liked the sound, other than the lack of stage height it presented. most music at higher volumes the stage height would seem high enough but at lower volumes they sounded like they were in the kicks.
i tried them at numerous angles on the pillars, using velcro and found on-axis to sound the best to me with these particular tweeters. any other way and the left side just lacked top end and the right side had to much top end. putting them on-axis really brought out the top end detail which i really like. i like the shimmer up top. i have the left tweeter at -2db(since it seemed louder because its closer) and the right one at 0. i have zero EQ on the tweeters as of now, other than a very small cut on the left side at 5k(to get them to sound centered).
