Hi all. I was wondering if anyone could tell me how the best way would be to do this install so that i can get the best possible sound QUALITY out of it, I want it to be loud and nice deep low bass, but with good quality.
This is what I want to run:
Panasonic Head Unit with FIVE, 5V Pre-outs
- 2 AUX IN
- 1 FRONT
- 1 REAR
- 1 SUBWOOFER
4 Channel Alpine amp, older amp, about 10 years old, its 50 X 4 RMS, I want to use this to run my 6 x 9's and 3.5's up front, both fo which are JL Audio, I can select LP, HP, or off.
E1200 JL Audio amp, 1 X 275 RMS, bridged inside, it can run 2 subs, but its class AB Full Range amp, to power 2 JL Audio W1's in a custom made enclosure from JL.
What is the best way to do this? I have one power wire running to the trunk that can handle up to 800 Watts of power, Can I run that wire to one amp, then use another wire to run from that amp, to the positive terminal on the other amp, ground both amps in the same spot, and use the same remote wire for both amps? Basically just distrubuting it all. It shouldnt rob much power I wouldnt think seeing as between both amps, the most I would ever demand out of the setup is 475 watts.
Also what abotu RCA's? Do I have to run a pair of RCA cables for the REAR RCA outputs on my deck and a pair for the FRONT RCA outputs on my deck, run these to my alpine amp and put them in the corresponding spots?? Thanks!
- 2 AUX IN
- 1 FRONT
- 1 REAR
- 1 SUBWOOFER
