Amps
Continuous Power (20Hz-20kHz, 0.04% THD)
2 ch: (4 Ohm) 100Wx2
2 ch: (2 Ohm) 200Wx2
1 ch: (4 Ohm) 400Wx1
Maximum Power (EIAJ)
2 ch: (4 Ohm) 250Wx2
1 ch: (4 Ohm) 750Wx1
Frequency Response: 10Hz - 50kHz (0,-1dB)
Total Harmonic Distortion:
Signal-to-Noise Ratio: >105dB (IHF-A Weighted, at 1kHz)
Dimensions: 10-3/8" x 2-1/2" x 13-5/8"
Features
Bridgeable 1/2/3 Channel Capability
PWM Regulated MOSFET Power Supply
2 Ohm (4 Ohm mono) Optimized MOSFET Output Section
I dont think so, usually it will say
good luck guy.
http://www.pioneerelectronics.com/Pioneer/CDA/CarProducts/CarProductDetails/0,1429,751,00.html
I own a PRS-X720 myself and I'm running it at 4 ohms. I haven't tried it but that is a very clean amp and I wouldn't want to burn it up by trying it. But its your amp.......if its worth the risk to you go ahead and try it.
mark 26
mark 26
louisiana
Larrydehp920r
Doxquzme
    Jun 20, 2026
Doxquzme
    Jun 20, 2026
