i think thats jakes way of saying that he feels confident that the amps are stable below 1 ohm. however, he is only going to warantee the amp for failures due to under impedance if said failure is caused by the woofer brand that jake has a marketing agreement with //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif .That doesnt seem right. Either your product can handle the .5 ohm load, or it cant. Not really fair to have it warrantied only if you use a certain brand of subs.......
Having said that, of course its your company, so its your call.
agreed, i thought about the same thing for a setupThat doesnt seem right. Either your product can handle the .5 ohm load, or it cant. Not really fair to have it warrantied only if you use a certain brand of subs.......
I'd get the IA 20.1 for the pair of Mags, to the original poster.
no. if someone needs 1500+ at 1 ohm, he recomends his amps //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif . if someone needs ~2000+ at .5 ohm, he does not recomend his amp, unless the subs are SI Mags OR BM's.so if someone needs an amp that does 1500+ at .5ohms, you do not recommend your amp...unless the subs are SI mags?
is the same dang thing lolno. if someone needs 1500+ at 1 ohm, he recomends his amps //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif . if someone needs ~2000+ at .5 ohm, he does not recomend his amp, unless the subs are SI Mags OR BM's.
i would suggest it to someone who wanted power at .5 ohm. im not affiliated with the company, but i think it has no problem running beliw one ohm. i havent tested the limits of safety for lower impedances, but i think .5 ohm is safe. however, should the amp fail, its not under warranty.I'm not gonna argue about the man's business choice, its his company...not mine //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif. I just wanted to get this out in the open and get a reply from him. Cuz I don't wanna see people recommending this amp to folks who need one that does power @ .5ohms. Unless its an SI, of course.
Imo if the manufacturer tells you not to buy his item for a certain install...then dont //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif.i would suggest it to someone who wanted power at .5 ohm. im not affiliated with the company, but i think it has no problem running beliw one ohm. i havent tested the limits of safety for lower impedances, but i think .5 ohm is safe. however, should the amp fail, its not under warranty.
but, i think as long as you dont go crazy, you shouldnt have a problem. only woofers i could possibly see having an issue, are XBL^2 woofers, or any variation of that technology that keeps impedance rise to a minimum.
For some reason that made mejust tell people buy it to run at .5 if you want a voided warranty for not having the right subs
