Amplifier Power Question
  • Thread starter Unregistered
  • Start date
  • Replies 1
  • Views 1K
  • 1
U
Unregistered
Guest
When I select my amplifier, do I want a 12 volt unit, 14.4 volt unit, or a 17 volt unit? If I should get one of those higher voltage amplifiers, and my car charging and power is only 12 volts (altermator actual = 13.8 volts), how do I get the 14.4 or 17 volts to my amplifier?
Thanks
Christopher
the amps arent actually different voltages, that is just what the company uses to test the amps and show you the ratings for. so an amp that says 150 watts at 12v is actually more powerful then an amp that says 150 watts at 14.4 so lok for an amp that makes a good rms power at the lower volts when your car is running it puts out 14.4 a lot and a cap can help raise it.
Like @maylar said, delay the turn on to the amplifier only. 3 to 5 seconds should take care of it.
8
237
Google and Ebay are your friends. Froma quick search and providing these are like new, $2- $400 for the subs and $2- $400 for the amplifiers...
The CT's are nice, That Sundown is a a frik'n beast!
7
807
812
Guest
EPanther99
winkychevelle
    May 24, 2024
