Amp wiring questions
  • 2
Primetime
Senior Hoopster
454
Tx
I have a JL 1000/1 and a JL 300/4 amp. The 1000/1 is running @ 2ohms and the other is running at 4 ohms per channel.
What size Power Wire should I use to hook them up? I have been told that 4awg will do the trick. But is that for each? should I run some bigger stuff, then run that into a distribution block to 2 seperate 4awg wires? OR should I run two seperate power cables to each amp straight from the battery?
D
How for does the wire have to go? To be safe in any case i would run a 2 guage or even a 1/0 guage wire from the battery to a distrobution block and from the block 4 guage to the amps. That should set you up.//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Originally posted by Jmac 1/0 AWG to distribution block, 4 AWG to 1000/1, 8 AWG to 300/4 ...
That would be your best bet right there.//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
two d2 subs can be wired to .5 or 2 or 8 ohms not 1 heres how to wire subs...
hi all, thanks for allowing me to join your site. im installing 2 soundstream tx4.560 4 channel amps, but i want to run them as 2 channel...
485
In a case like In a case like yours I would rather recommend tactile transducers. They are like woofers without the cone section that are...
966
I have a jeep wrangler 2010 4 door.. So 2 of my speakers are in the dash upfront. And the other 2 are in the bar in the middle of the car
Primetime
Senior Hoopster
Primetime
Tx
80_Cutlass_mn
    May 24, 2024
