Amp Wiring Help.
to run two amps you will either have to get distribution blocks for the power and ground or run two seperate power wires from the battery to the amps.. use the same ground for all amps though.. then, just tie the remote wires together running to both amps.. make sure at least one of the amps has a RCA OUTPUT as well as a INPUT or the head unit has 2 sets of RCA output lines.. otherwise, you'll need a Y splitter for them.
In a case like In a case like yours I would rather recommend tactile transducers. They are like woofers without the cone section that are...
7
934
No not in this situation.PM sent for proper use of the Y splitters for this situation
34
5K
problem was the LOC burnt out when I had touched cables. got a new LOC and now all is working. have to get the gain right, lights flickering with...
11
well ****, thanks anyways. Will leave the thread open just in case someone knows anything :)
smggolfer
smggolfer
Virginia
bronco2323
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
