amp wire kits?
hockeytoker
ok so im plannin on gettin 2 audioque HDC3 12's and 2 aq2200d amp(an amp per sub).
ok im a total noob an i really dont no anything about wires and stuff like that.
so do amp install kits hook the amp up to the sub or the amp to the batt?
also will i need 2 amp install kits since im hooking up 2 amps to 2 subs?
i was thinkin of gettin these wires but will i need two sets of these? and what amp fuse should i get? http://www.knukonceptz.com/productDetail.cfm?prodID=KFX-PK0
would this work for hookin up 2 subs to 2 amps?
http://www.knukonceptz.com/productDetail.cfm?prodID=KFX-PK20
any feedback or recommendations help thanks!!
Also that kit you picked out splits 0g into 4g and those aq2200's have 0g inputs and would not like 4g unless you did 2 runs of 4g to each power and ground on each amp.
hockeytoker
hockeytoker
Highlands Ranch, CO
bass-aholic
Mike Mccabe
