amp to sub wiring.
Bullet03
I have 2 kicker cvr12's (4 ohm) powered by a crunch p1100.2 i have them wired at 4 ohm in series, bridged at them amp. which is how i was told to do it from kicker, as well as from many on here, my question is would it be better for the subs if i wired them one to each channel on the amp, if i plan on using them for most of a 6 hour trip im about to go on? or should i just leave it as is and they will be fine? i know its a newbie-ish question but just want to do what will be best for them if i plan on using them for most of the trip.
The amp would be less efficient with a 2 ohm load rather than a 4 ohm load, but probably something you wouldnt even notice. I'd just leave it as is.
i was thinkin the same. i just didnt want to burn up my subs by allowing them to play that long, not that i will let them run for 4-6 hours straight.. but just a question. thanks for a quick answer.
Bullet03
Bullet03
Atlanta,GA
Bullet03
vegang
vegang
