Amp to run these four sets??
  • 4
jeeper2269
I’m looking at running the following in a new Jeep (after recommendations from forum members)
would like to know what amp you would suggest.
Polk DB 351 (35 watts rms each speaker)
Polk DB 402 (45 watts rms each speaker)
Polk DB 652 (100 watts each speaker?)
Hertz DCX 87.3 (30 watts rms each speaker)
thanks guys.
thanks guys.
I'm running those in my pickup. There's no real "best amp" answer. You want something with really low THD, and 100-150w RMS per channel.
I recommend wiring to the 2 ohm load on the amp you stated you have, or you can wire to an 8 ohm load for amp stability. You can wire one sub to...
117
  • Locked
294
jeeper2269
jeeper2269
Somewhere, OR
jeeper2269
    May 18, 2024
    May 16, 2024
