I'm fairly certain the gain is not a power meter.It would be a waste of money to buy a new amp. There's a gain knob. If it's to much power turn the gain down.
What do U mean? Small power wire or something? Any 4g wire should be good enough for that amp. Just because an amp says 600watt at 4ohm doesn't mean your going to get 600watts... when playing music the ohm load fluctuates and power is all over the place. And there is rise. Most amps in a daily situation see about half power they are rated forThe reason I asked about the electrical, is that my car was wired for an amp of around 600w. If I were to double that, I would need to rewire.
Ok last question. So running this at 2ohm on my current amp shouldn't cause problems?
what they saying is 6-700rms @ 2 ohm is same as 6-700rms @ 4ohm amp is still drawing same power..Ok last question. So running this at 2ohm on my current amp shouldn't cause problems?
Assuming the amps have the same efficiency...what they saying is 6-700rms @ 2 ohm is same as 6-700rms @ 4ohm amp is still drawing same power..
