Amp/Subwoofer issue: no sound
SchollStang
Here is my setup (just purchased everything new), no sound from subwoofer:
Kenwood KDC-BT365U Reciever
Kenwood KAC-5001PS 300W @ 4ohm 500W @4ohm Reciever
10" Polk Audo DB1040 4Oohm @ 270 continuous Watts, 540 Peak Watts
Amp is receiving 14V, Ground is reciting 4-5V, Remote is receiving 6-7V.
Tested the RCA cables from the head unit, each give off reading with my DMM on AC setting
Speaker wires to the subwoofer have AC going to through while music is playing.
The head unit has the subwoofer set to on, frequency to pass-through, and gain to 0.
That's alot of voltage on the gound side! Check the amp ground. Make sure it's on solid, clean bare metal and tight also tight with full contact area on the amp side. Also what do you mean by gain set to zero? That may also be an issue but either way that's too much voltage on the ground should be 0 volts or maybe a couple tenths.
SchollStang
SchollStang
Long island
nismotwin
Mike Mccabe
