amp-sub wiring question
  • 4
Mercureie
Stay in S-C-H-O-O-L
ive got a 2-channel amp that puts out 150 watts per channel and a dvc sub 300 rms(150/vc im assuming), dual 4 ohms. I was wonderin what the best way to wire them would be, i don't think my amp could handle a 2 ohm mono load, but would wiring the vc in series then bridging the amp give me enough power? o yea, also if the best way to wire it would be to just put each coil into its own channel, would i need two places for the wires to exit the box?
Originally posted by Mercureie ma audio, m286i, its 2 ohm stereo stable and 4 ohm mono stable i think
DO NOT put a dvc subs coils into separate channels. You will end with a world of not so good stuff. Sending two separate signals to one speaker.......and then trying to make that speaker reacte two separate ways? Bridge the amp if it is able to handle the 2ohm load you should be fine.
Originally posted by Mercureie thnx man. one more question, if i wired an 8 ohm mono load would that provide the same power as two 4 ohm's in each channel?
Technically yes, but if the amp is capable of a 2ohm load why not go that route instead and get a bit more power to them?
Check with your MA dealer or their website and see if it's 2 ohm stable bridged. Most of todays amps are. If it is, that is the way to go. If not then yes run your speakers in series for an 8 ohm load.
two d2 subs can be wired to .5 or 2 or 8 ohms not 1 heres how to wire subs...
One or two, they are still subwoofer outs and are mono summed signals from both left and right. Even the 2 RCA subwoofer pre-outs on the 2nd one...
622
Using a Y RCA to split signal from amp to amp to give both amps the signal they need from the HU and subs in different /separate enclosures tuned...
737
Hahaha his brother got some from a friend. American bass amp and some alpine s 12in subs. From a buddy of his now Eastons chomping at the bit...
9
737
Hello all. Used to come on these forum quite a bit. I used to compete in IASCA MECA etc. and placed 1st 2x with this setup. Anyway this is my baby...
Mercureie
Stay in S-C-H-O-O-L
Mercureie
Cleveland, OH
Mercureie
winkychevelle
    May 24, 2024
