Amp/Sub Problems.
MrQuA4ttro
Just looking for some more troubleshooting ideas before I declare that my amp is done for.
I have a single 10" rockford P1 subwoofer powered by the Eclipse EA4000 amp. I have never had any problems until the beginning of this past week. Turn on the car, the amp turns on, but no bass. I checked all fuses--2 30A @ the amp. & those are good. I have 0VDC at the subwoofer terminals. The sub is bridged. I also have a line level converter coming off the amp to power the factory sub deck in the rear of the car. Im pretty sure thats not working either. Im pretty sure that all outputs are tied together some how---meaning if I dont have one, I shouldnt have another--all or nothing. I dont want to come to terms that my amp is done---any other ideas?? Im not sure how reliable my voltage readings are either--I have a cheap craftsman multimeter--and that claimed to have read 0VDC input power--which I know is BS cuz my amp turns on!!
Any ideas would be helpful.
I would say make sure you have voltage at the amp between the positive and negative terminals, check the under hood fuse. Most of the time if this blows it will be a hairline fracture, put your meter to ohms and make sure you have a dead short.
Sorry, I had overlooked the mentioning that I had also checked the in-line fuse under the hood--its good. I know for a fact, that I have good power between pos and neg terminals @ the amp---even though my meter says 0VDC--for the mere reason that the amp turns on.
Anyone else?? Any other ideas? If I get some free time today, I'll go a second round of T/S.
MrQuA4ttro
MrQuA4ttro
Denver, CO
MrQuA4ttro
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
