Amp Question
  • 3
brett75
5
LA
I have the following installed:
Alpine CD player
4 Infinity 5 x 7 speakers (1 in each door)
Alpine 4 channel 75 watt amp
At louder volumes any songs with a lot of bass really
distort the speakers. I listen to a lot of rap and hip-hop
music and the bass just sounds like **** when it's turned up.
Do I just need to add a subwoofer or is the problem with the 5 x 7 speakers?
If I added a sub could I just power it from the Alpine amp - like 2 channels
for the front speakers and 2 for the sub?
I just want clear accurate bass response without distortion.
Any one have any suggestions?
Thanks.
Most 5x7s can't play lower than 50hz. And at higher volume will have trouble with anything below 100hz. If you want cleaner sound and more bass you will need to add a subwoofer to handle the low frequencies (20-100hz).
Someone told me if I replace the Infinity 5x7'x with
5.25 in. speakers it would get much better bass response.
Is this true?
The majority of 5.25 inch speakers are designed for midrange sound. Bass will cause distortion an possibly damage these speakers at high volume.
If you must use a 5.25 inch speaker for bass, I think FOCAL makes a 5.25 inch subwoofer. Bigger is almost always better when it comes to bass.
dewd, you'r close to a VERY PERFECT SYSTEM for listening to RAP....
u'r alpine is (hopefully?) a V12?
If so, put the ***** on HP (atleast front, maybe rear you can use normal with frequenty changes) and put another *****-ass enclosed sub in your trunk..
Maybe an mtx thunder (two 12 inchers) or some infinity //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
If you have a bit more to expend I really advice you the 12d elite sub from PG, its mad expensive but it gives you a real good bass, heavy but with lotsa quality
I currently have one of those subs powered by my octane amplifier and this already gives me a kick-ass bass which is a good thing considering the fact that using the octane for a mono feed is simply nuts (octane = highly exotic amp.. just like reactor)
One or two, they are still subwoofer outs and are mono summed signals from both left and right. Even the 2 RCA subwoofer pre-outs on the 2nd one...
339
Hell... Run It.. You will be ok @ that Ohm load(2.67). Just dont go below 2ohms and you will be fine. 2ohms is the lowest stability of that...
5
If you do use speaker baffles.. I recommend the plastic ones rather than the foam ones, and drill a 1/4" hole at the bottom of it in the back for...
9
Haven't 100% landed on which one, but I am down to those two
12
That makes sense. I took it apart today. It doesn't look too impressive but it should be better than the head unit. I'm going to install something...
8
brett75
brett75
LA
beastyle
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
Latest topics
