Amp question
  • 2
ace_800
I've got the 2 PG amps that are in my sig using the same line for the remote turn on. When I originally installed them about a month ago the would turn on at the same time. Now the 4 channel takes about a second or 2 longer to come on than the sub amp. Anyone know why? Stock HU since I can replace it, using a PAC unit to bypass the BOSE amp. The same thing would happen with my JL sub amp I had previously. Would it have anything to do with the pac unit adjustable settings? I haven't changed them since I got it, they are set in the middle.
760
Hell... Run It.. You will be ok @ that Ohm load(2.67). Just dont go below 2ohms and you will be fine. 2ohms is the lowest stability of that...
If you do use speaker baffles.. I recommend the plastic ones rather than the foam ones, and drill a 1/4" hole at the bottom of it in the back for...
Haven't 100% landed on which one, but I am down to those two
That makes sense. I took it apart today. It doesn't look too impressive but it should be better than the head unit. I'm going to install something...
ace_800
ace_800
Okinawa, Japan
ace_800
