Amp question/problem
HW60068n
18
NY
I have a problem with my subwoofer amp. It is a bridged 2ch amp. I also have a 4ch amp. The bridged 2ch always get hotter than the 4ch. And today it was extremely hot which the amp was shut off all of a sudden. Once i pop the trunk it cooled down a bit and it started to work again. Anyone ever experienced something like this?
Can someone explain to me what LPF and HPF are? Is that has to do with the crossover frequencies? I'm also having trouble figuring out what frequencies to set it to so i can fine tune my amps. Any info will help alot. Thanks.
HW
your amp prolly has thermal protection, which means it will shut off when it gets too hot. there could be many reasons to why it gets so hot. what amp is it, and what subs are you running to it? also what size power wire do you have?
I'll have to second BB's guess that the cause for your amp temporarily shutting down was from it tripping the thermal protection function.
Most amps have such a thing but the specific temperature that trips the safeguard varies from manufacturer to manufacturer. Usually, though, it is somewhere around 185 degrees Farenheit internal temp (give or take)
As far as the other portion of your question.
HP is going to be for High-P*** filter and the LP is going to be for Low-P*** filter. These are crossover functions which, depending on which filter it is, bar either the lower or higher frequencies from getting through to drivers that aren't well-suited to reproduce them.
High-Pass filters attenuate the frequencies below the selected cutoff point. The level of attenuation will be dependant on the slope of the crossover in question. The steeper the slope (generally measured as follows ~ 6dB/octave, 12dB/octave, 18dB/octave, etc etc etc) the sharper the attenuation of the frequencies below the cutoff step.
Low-pass filters are going to be just the opposite. They will allow the lower frequencies through and attenuate anything above the selected cutoff frequency.
So - their names make it easy to tell which is which and what function each serves.
High-Pass filters allow high frequencies to freely pass the filtering electronics while attenuating the lower freqs.
Low-Pass filters allow the low freqs to freely pass through while attenuating out the higher freqs.
So - with this in mind the high-pass filters are going to be appropriate for your interior speakers (mids and highs) since they are designed to provide you with all the frequencies above the subbass region.
The low-pass filters are going to be for your subwoofers to keep out all the frequencies better suited for your interior speakers to provide you.
Thank you Prowler for the great explanation. I am still trying to fine tune the amp. I already calculated and set to the appropriate voltages. But i am stuck at tuning the crossover frequencies. That is why i was asking about LPF and HPF. What is the correct way to set the frequencies of the crossovers?
HW60068n
HW60068n
NY
HW60068n
Mike Mccabe
