good amp that does 2000+
Where do you get those numbers? Re value? Not an accurate indication of what hte sub will actually present to the amp. 1 and 4 ohms are pretty much your options and those subs aren't really going to need or like that kind of power.
If that 1000/1 on the W6s isn't cutting it for you, I would suggest trying differenct subs or a different enclosure rather than more power on the W6s.
^^he wants to keep his subs. i dont know if he decided on keeping 2 or all 3. and his 1000/1 wouldnt be enough for them if he wanted to keep all 3. and i dont htink itd be stable for all 3?
Didn't notice that you had 3 subs. With proper electrical prep the SAZ-1500d should do what you want. Won't be covered under warranty, but that shouldn't be an issue. Another option would be to get a second 1000/1 and run them master / slave with a coil form each sub wired to each amp. 1.33 ohm load on the amp, but with impedance rise, that shouldn't be a problem.
spike_e
ballin on a budget
spike_e
prattville AL
spike_e
